DR180 rebore advice
What clearance are people using beedspeed say 3thou someone else has said standard vespa use .035mm or1.37 thou as standard and 3 thou would be way to much piston is asso (INCREDIBLY only 45gbp) opinions please
goldeneye
last DR180 I had rebored I had 4 thou clearance on it, it rattled a bit at tickover , but DR"s do anyway. its been on the lads scoot for 4 years no probs. good cheap kits when set up right.
goldeneye wrote:last DR180 I had rebored I had 4 thou clearance on it, it rattled a bit at tickover , but DR"s do anyway. its been on the lads scoot for 4 years no probs. good cheap kits when set up right.
cheers
