smallframe setup
maxi
Main scooter: LIS 190
Looking for some advice on kits and other goodies for my engine. I am wanting something that will keep up with my Ts1 if my wife fancys coming along : ). The plan was to put a falc into her, but with me moving will have to wait until I get a spare engine.
cheers maxi
Ride it hard
Falc 200 kit?
here
soosh
Top end or acceleration? I guess you will say both.My Parma will sit at a gps 65+mph comfortably.Thats cruising and is about the same as your average TS1.Acceleration the same if not quicker!
maxi
Just what iam after soosh. What setup have you got?
Ride it hard
jonny snatchsniffer
the parma kit needs a lot of work but its ok ish i had the exhaust timing up to 190 but it wasnt quite enough, its a basic design based on an old pinasco barrel, i now use a polini evo rotary with a 35mm keihin and franz pipe, and it will sit at 70 at around 8000rpm and rev out to 9500rpm with my head down, i use 29/68 primarys and a drt runner tree which gives you a short 3rd and 4th
it has a wide spread of power and 1st will easilly spit you off when it comes on pipe
i broke it sprinting as the clutch was slipping like f@@k but my 1/8th mile speeds were not too bad at around 60mph
