New mappable Lambretta ignition from Charlie Edmonds......
......i understand one is being brought out, it has been tested on road and dyno (and at Elvington at the last sprint meet) and is producing up to 30% more power through the midrange etc. Resulted in better top speeds on the sprint track when tested back-2-back against the previous non-mappable ignition fitted.
Anyone got more info or pictures???
rbgaz
hi monkey, could u explain for me what a mappable ignition is , cheers
DigDug
It means you can preset your timing to alter it across the rev range.
Did you have to do that?
Muppet
DigDug wrote:It means you can preset your timing to alter it across the rev range.
how :?
C’est la vie
rbgaz wrote:hi monkey, could u explain for me what a mappable ignition is , cheers
In laymans terms...
Standard ignitions fire at a fixed point...whatever the mechanic sets it at, say 17 degrees before top dead centre (17 BTDC) or 19 BTDC etc.
The currently available advance/retard ignition boxes can be added to retard the ignition in a linear fashion, for example they might start at 20 BTDC and retard back 1 degree every 1000rpm.
So 20BTDC@1000rpm, 19BTDC@2000rpm, 18BTDC@3000rpm and so on.....
However a mappable ignition can go back and forth in any direction, any amount of degrees. So maybe 20BTDC@1000, 15BTDC@2000 18BTDC@ 3000 etc...any amount in any direction at any RPM.
It creates 3D maps like this:
Ignition adjustment example PS11 by Scooterotica Scooter Garage, on Flickr
pgm-2-2 by Scooterotica Scooter Garage, on Flickr
This all helps to broaden power-bands and extend RPM ranges effectively.
Muppet
But how do it do wot it does?
C’est la vie
Muppet wrote:But how do it do wot it does?
Fairy dust and magic....
Muppet
Send me sum :P
C’est la vie
Send me sum :P
The pixies have it all.....
Muppet
:lol: :lol: :lol:
C’est la vie
