Mugello 225 with 60x107 crankshaft packers and gaskets.
Trifero
Main scooter: Lambretta GP 200
Hello:
I have a mugello 225 with a 60x107 crankshaft:
What should be the measures of the base gasket and head gasket?
Thank you very much.
That depends on you casing. Assemble it with no gaskets and measure how far in or out of the top of the barrel the piston is ay TDC.
Then nip down the head and check the squish gap, you're aiming for < 1.5 mm. Then its just arithmetic.
You can adjust the base and head gaskets within that range to get the desired results.
Sent from my HTC Desire C using Tapatalk 2
