lambretta antidive kit
frankie
Hi who would you guys recommend to buy an anti dive kit from for my GPdisc brake thanks :oops:
Martin (Corrado) on here does them at Just Lambretta
If you have a standard disc set up you'll need to change this to a completely new hydraulic disc brake and hub with anti-dive of which there are a few options depending on budget.
jonashford
Ive just ordered a volante set up from Frank Sanderson, Ill post my findings next week when I have got it on
boonyed
Get some BGM shocks........worked for me :-)
Elite-225
Main scooter: GP 225
The original question was .. " are there any recommendations for the use of them" , or not .. ???
Elite-225
Woops !.. (I miss read it)... But are there any ??
Den 08
frankie wrote:Hi who would you guys recommend to buy an anti dive kit from for my GPdisc brake thanks :oops:
Yes
They feel weird at first but once you use to them they are the biz
I run franks twin disc setups with anti dive on both my ts1`s a bit overkill but they do look trick and f##k they work if you got bottle you can do an endo and the front won`t dive :lol:
there is no dive which is good when breaking on corners even at slow speed so it does give you more confidence, (Placebo effect maybe) I certainly will not use the standard setup again.
