exhaust fitment muggy to cylinder
idc1967iow
Is a muggy 186 cylinder the same as a standard iron barrel for fitting exhaust flange??
Thanks
Ian :D
thebassmasta
Main scooter: GP TS1 240
yes standard fitment
idc1967iow
Thanks for the info
CPH Lambretta
Main scooter: DL 150 1970
If its a recent version ie a V4 kit then no not by a long shot. The recent Mugellos have the exhaust gasket face around 15mm further away from the piston skirt than standard (when the cylinder is fitted the exhaust gasket is 15mm closer to the ground than standard, it was done to aid gas flow out of the cylinder). This can make exhaust fitment a real bitch,see MBs comments about the Mugellos on the BGM clubman thread.
If you meant is the exhaust gasket the same type/shape as standard then yes :D
Slow is the new fast!
