s**t cluch
who does decent thin clutch plates ..these cork ones I have are impossable to stop drag
10 inch Terror
Xbox live gamer tag: No.
RICSPEED wrote:who does decent thin clutch plates ..these cork ones I have are impossable to stop drag
Readspeed do a 5 plate kit complete with springs design to use with standard clutch baskets and components. I use one in my Imola and I can't fault it. It's under £40 too excellent value.
Rich_T
Main scooter: Li Special
Check the clutch carefully, I'd bet you find the drag is down to a slight warp in the steels or the basket and release plate not running concentric. Concentric issues could be either bent/worn parts or odd springs fitted without ground ends. The cork material is not likely to be the single cause of clutch drag.
got upreated mb springs but its so damn heavy ..thought I had some original inocenti plates but they seem to be
awol
thing is I need is sorting asap for shoot out :(
was hoping to have the aprilia one bunged in by now :(
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 20 guests
