Lambretta barrel ona Vespa
mick1
Main scooter: Li Avanti 225
There are 2 options when putting a lambretta barrel on Vespa casings: 1=Blank off barrel inlet and run rotary induction as per casings or 2=blank off casings and use barrel inlet.
My question is. Could the same piston (the lambretta one that comes with the barrel) be used for both methods and what advantages and disadvantages are there with both options ?
ducksta
blanking off the rotary inlet is the best option, depends on con rod length etc if piston could be used?
think it was oz that put a ts1 on a p range
RICSPEED wrote:think it was oz that put a ts1 on a p range
Be interesting to know what it went like ! Crackers I reckon
