Phbh 28mm 50 slide
Posted: Sun Sep 01, 2013 9:15 am
by Realpoke
I have a 28mm phbh carb with a 50 slide which will be going on a standard rapido classic 225 I know the the norm is a 40 slide. I will be roughly starting with av 266 x7/13 needle 300 needle jet and 55/60 pilot and a 128 main and no filter and a jl3... Will it make that much difference? Any advice would be gratefully received cheers
Re: Phbh 28mm 50 slide
Posted: Sun Sep 01, 2013 7:55 pm
by 1469leach
In short yes. Your slide has an influence on the air fuel mixture up to 1/4 throttle, the bigger the cutterway in the slide the weaker the mixture will be, could be a problem if your sitting on a open road at 1/4 throttle for a long time. My Rapido is using a 30 slide at the minute so they do differ.
cheers Jeff.
Posted: Tue Sep 03, 2013 1:15 am
by Realpoke
Thanks Jeff info much appreciated
Posted: Tue Sep 03, 2013 1:01 pm
by stokky
will now have to go and check mine to get exact settings, but from memory think I tried with main jets of 125 and 128 with similar setup, didn't work.
Again only from memory, but think went down to a 115
Posted: Tue Sep 03, 2013 10:50 pm
by Realpoke
Many thanks pal
