converting serveta motor to tv piston and rod with gp webs
maz66
i have an af stage 4 barrel and head that has caused me nuttin but major grief so gonna convert it to tv piston and rod with gp webs
any info ideas on best gear box set up drive teeth etc appreciated have an af big bore but not decided on carb yet
cant seem to find anything in the search option so any klinks would help
cheers maz
If your gonna be a pervert -Be a happy one
Muppet
62 or 66mm bore?
C’est la vie
why use a tv rod ?? are you converting 150 to 175 ??
maz66
stage 4 175 barrell the tv rod and piston will give less vibration and smoother running
maz66 wrote:stage 4 175 barrell the tv rod and piston will give less vibration and smoother running
fair point .. what box /sprockets are you currently using ?
