MUGELLO 186+PWK 28/30+SCOOT RS PIPE
Posted: Mon May 11, 2009 10:59 pm
by pasner
Not idea at all, could anyone help me? gearbox is Li150(italian).
Any advice wellcome.
Re: MUGELLO 186+PWK 28/30+SCOOT RS PIPE
Posted: Mon May 11, 2009 11:42 pm
by storkfoot
This is mine, mate. Your carb and pipe are similar to mine, although your gearing isn't. This should be something to start you off anyway:
Engine: v2 Mugello 186, matched inlet and exhaust, 125 Special gearbox, 47/18 sprockets
Carb: bgm Keihin copy PWK 28 with CamLam long RamAir filter through the panel.
Pilot: 42
Needle; GJH- 2nd clip from top.
Main; 128.
Float set at 22mm.
Timing: 18deg. Electronic.
Exhaust: PM 25 expansion.
Having run all sorts of different configurations over the past couple of years, this is the best I've had. Carb came with a bgm needle marked "28" which proved a bit rich. I tried a JJK thinking this would be leaner over half throttle only to find the opposite. Fitted a GJH and it transformed the midrange but needed the main lifting from 115 to 128.
Posted: Tue May 12, 2009 7:46 am
by pasner
Thanks mate, I would try next weekend! :bald:
Posted: Tue May 12, 2009 9:03 am
by storkfoot
storkfoot wrote:..............., although your gearing isn't.....
Actually, the 4th gear ratio of 5.2 is, if you are running standard 46/15 sprockets. If so, I would suggest this is a good ratio for your set up ;)
Posted: Tue May 12, 2009 1:59 pm
by pasner
thats it, Im running standard 46/15 sprockets.
Posted: Thu May 14, 2009 12:16 am
by pasner
Any other mugello 186 setup wellcome!!!!!!!!! ;)
Posted: Tue Feb 14, 2012 10:29 pm
by deanlam185
Hi I've got 186 mugello with lth reed was thinking about pwk 30 pj trying to get a guide on jetting for it I'm using 30mm phbh at the moment. I need to get in shed to check setup on it think it's 125 main x2 needle Jl3 no filter
Posted: Wed Feb 15, 2012 1:06 am
by coaster
This is the setup of mine
Engine: Mugello 186 Mk1 (Reaper head), cases matched to the transfers and manifolds matched to the ports.
Carb: OKO PWK 28/36 with foam remote filter on GP bellows
Set up: 34 pilot
Needle: GJH top clip
138 main, arrived at after burning holes in first 2 pistons with smaller jets.
Timing: 18deg.BTDC but will try 17deg when I get round to it (Standard Indian electronic setup.
Exhaust: Sito Ancilotti.
Now runs clean through all the gears with some slight 4 stroking when the throttle is backed off.
PS, this along with others has been on the Carburetta Setup thread for a year or 2, it's worth exploring ;)
