MUGELLO 186+PWK 28/30+SCOOT RS PIPE
pasner
Not idea at all, could anyone help me? gearbox is Li150(italian).
Any advice wellcome.
storkfoot
This is mine, mate. Your carb and pipe are similar to mine, although your gearing isn't. This should be something to start you off anyway:
Engine: v2 Mugello 186, matched inlet and exhaust, 125 Special gearbox, 47/18 sprockets
Carb: bgm Keihin copy PWK 28 with CamLam long RamAir filter through the panel.
Pilot: 42
Needle; GJH- 2nd clip from top.
Main; 128.
Float set at 22mm.
Timing: 18deg. Electronic.
Exhaust: PM 25 expansion.
Having run all sorts of different configurations over the past couple of years, this is the best I've had. Carb came with a bgm needle marked "28" which proved a bit rich. I tried a JJK thinking this would be leaner over half throttle only to find the opposite. Fitted a GJH and it transformed the midrange but needed the main lifting from 115 to 128.
pasner
Thanks mate, I would try next weekend! :bald:
storkfoot
storkfoot wrote:..............., although your gearing isn't.....
Actually, the 4th gear ratio of 5.2 is, if you are running standard 46/15 sprockets. If so, I would suggest this is a good ratio for your set up ;)
pasner
thats it, Im running standard 46/15 sprockets.
pasner
Any other mugello 186 setup wellcome!!!!!!!!! ;)
deanlam185
Hi I've got 186 mugello with lth reed was thinking about pwk 30 pj trying to get a guide on jetting for it I'm using 30mm phbh at the moment. I need to get in shed to check setup on it think it's 125 main x2 needle Jl3 no filter
This is the setup of mine
Engine: Mugello 186 Mk1 (Reaper head), cases matched to the transfers and manifolds matched to the ports.
Carb: OKO PWK 28/36 with foam remote filter on GP bellows
Set up: 34 pilot
Needle: GJH top clip
138 main, arrived at after burning holes in first 2 pistons with smaller jets.
Timing: 18deg.BTDC but will try 17deg when I get round to it (Standard Indian electronic setup.
Exhaust: Sito Ancilotti.
Now runs clean through all the gears with some slight 4 stroking when the throttle is backed off.
PS, this along with others has been on the Carburetta Setup thread for a year or 2, it's worth exploring ;)
