expansion pipe again
boris
Main scooter: lambretta
ok then fellas I know Im going around the houses a bit with this exhaust.
But I have narrowed it down to either a.
stirling.
scootrs.
scooterotica performace.
(on a tight budget due to near full engine rebuild)
Im running a 200gp box and 5.2 ratio 28mm phbh
With your experience which one do you guys recomend and why.
thanks again sorry to be a pain fellas.
CPH Lambretta
Main scooter: DL 150 1970
Whats the rest of your set up ie cylinder?
All the pipes you have named are just PM copies from 3 different companies in Vietnam, so just take your pick.
Slow is the new fast!
And all revvy so would suit the 5.2, if your budgets tight place an ad in wanted
For a 2nd hand one (any of the 3) must be a few sat In sheds/garages with all these franspeeds popping up.
boris
The new RT 190 kit. I had an NK rally but it drove me crackers too loud.
IT was good for traveling about with the lads with RBs. But even they started to complain about the noise.
