48mm AF reverse cone exhaust
Dimitrios_231
Will it be an overkill,if I use one for the 225 Classic Rapido with TM24?
Currently I use a cut Sito Ancillotti without problems.
Just need a little bit more performance.
Classic look only.
monkey boy
Hi
I've been advised by AF this is the pipe to use on a 225 clasic.
Would have thought the carb was too small to get full benefit from the kit though
30mm would be better.
CHEERS AL
