RB20 40 - 50 slide?
Posted: Tue Aug 06, 2013 10:36 pm
by sydduckett
Is anyone running a 50 slide in there RB20, this is presuming your using a dell vhsh 30. I run a 40 and noticed that AF,s site says 50 but when you call them they then say 40...
Anyway I presume the 50 would be a bit leaner. Need a new one so was wondering wether to try the 50
Ta
Sef
Re: RB20 40 - 50 slide?
Posted: Sat Aug 10, 2013 7:32 am
by Toddy
What's it running like with a 40 ? Mine ran a 40 in the same carb and dynod with it in as well
Posted: Tue Aug 13, 2013 8:21 pm
by sydduckett
Toddy wrote:What's it running like with a 40 ? Mine ran a 40 in the same carb and dynod with it in as well
At the moment like a bag of bolts, hence new slide and slide housing. But prior to that went well, always had good plug colour so wondered if knocking it up to a 50 might give me a bit more without being to lean. I have found a 45 on a couple of karting sites so was going to go for that but chickened out and brought the 40........again....
Posted: Tue Aug 13, 2013 9:11 pm
by bazman
Atomiser and needle ok as they wear very quickly, don't be tempted to go to a 50 slide as this can lean it right off when you shut down from high revs and nip up!!
I should know...
Posted: Wed Aug 14, 2013 8:27 pm
by sydduckett
bazman wrote:Atomiser and needle ok as they wear very quickly, don't be tempted to go to a 50 slide as this can lean it right off when you shut down from high revs and nip up!!
I should know...
Got in, slide arrived. Next door signed for it. They are now not in....
Was hoping to get out tonight......hoh hum
Re the atomiser i think ill probably replace that as well. Needle seems a bit loose as well so that will also have to go.
