RB20 40 - 50 slide?
sydduckett
Is anyone running a 50 slide in there RB20, this is presuming your using a dell vhsh 30. I run a 40 and noticed that AF,s site says 50 but when you call them they then say 40... :?
Anyway I presume the 50 would be a bit leaner. Need a new one so was wondering wether to try the 50
Ta
Sef
What's it running like with a 40 ? Mine ran a 40 in the same carb and dynod with it in as well :D
sydduckett
Toddy wrote:What's it running like with a 40 ? Mine ran a 40 in the same carb and dynod with it in as well :D
At the moment like a bag of bolts, hence new slide and slide housing. But prior to that went well, always had good plug colour so wondered if knocking it up to a 50 might give me a bit more without being to lean. I have found a 45 on a couple of karting sites so was going to go for that but chickened out and brought the 40........again.... :D
bazman
Atomiser and needle ok as they wear very quickly, don't be tempted to go to a 50 slide as this can lean it right off when you shut down from high revs and nip up!!
I should know... :roll:
sydduckett
bazman wrote:Atomiser and needle ok as they wear very quickly, don't be tempted to go to a 50 slide as this can lean it right off when you shut down from high revs and nip up!!
Got in, slide arrived. Next door signed for it. They are now not in.... :roll:
Was hoping to get out tonight......hoh hum
Re the atomiser i think ill probably replace that as well. Needle seems a bit loose as well so that will also have to go.
