ScootRS Master Cylinder options
Are there any smaller master cylinder options that will directly fit, with minimum fuss, the ScootRS light switch housing/master cylinder support? I've seen other options but don't think they'll fit the housing, unless I'm wrong :? Cheers
None, nothing, niet, nowt, nada? :(
cezeta
gremica do a much nicer one, slim and not so cheepo. sip do them.
ill be using a gremica p200 one on mine. its the best fit once a plate is welded to the swith housing and isnt from a 70s goldwing. those yamaha ones mounted three foot away from the bars are totaly gay.
