Hydraulic line end fittings
I recently bought a new hydraulic line off ebay without realising that it didn't come with the fittings on the ends to screw to the banjos. Does anyone know if it's possible to buy them separately?
Ta
Colin
stokky
Might depend on what Hydraulic line you've bought.
Expensive, but try Goodridge, they do something called "Build a Line" or similar.
Can choose different angles for banjo's
Search E*** you should find loads
10 inch Terror
Xbox live gamer tag: No.
I get mine from Venhill they have loads to choose from and even sell the olives separately.
Angry Bloke
stokky wrote:Might depend on what Hydraulic line you've bought.
That's what I use - very good :D
warts
Main scooter: honda
+1 for Venhil.
I'm not sure every brand of ss braided brake line is interchangeable. Maybe worth a check?
Thanks guys, that's given me a couple of options to try, an ebay search didn't throw anything up, even the seller that I got the pipe from even though he does make them up to order :?
gaz_powell
i always make my own up and have used Venhill and unbranded ends - they do chrome or stainless in every shape and form.
much easier when routing the hose
Venhill direct - but there is loads of info on the site to wade through
search e**y with brake banjo
Beedspeed have a decent range
gaz
gaz_powell wrote:i always make my own up and have used Venhill and unbranded ends - they do chrome or stainless in every shape and form.
gaz
Cheers Gaz
