vespa px 125cc upgrade options ??
paul59hatter
Main scooter: px 125
hi i have a standard vespa px125cc what is the cheaper option to upgrade engine to give it more poke ? dont want to spend silly money on expensive kit upgrades !!
Define 'silly money'.
And 'more poke'.
Do you want more revs or more power and speed for same revs?
paul59hatter
more throttle say up hills happy to sit at 65/70 mph,,,im on a budget been told cheaper options a 150cc cylinder replacement clutching at straws to be honest, just want to get a little more speed on the 125
soz to disappoint you ,but an upgrade to a std 150 cc just is not gonna deliver you what you desire as regards your up hill requirements and your 65/70 mph cruising speed i,m afraid
mick1
Main scooter: Li Avanti 225
P2 engine. straight swap and no messing about with jetting, clutches, cranks, etc........maybe not get the MPH your after but you'll be closer
paul59hatter
thanks for all the advice so far will chew on it !!! im not mechanically minded and have not got buckets of dosh to throw at the 125 cc so all advice is appreciated cheers, just find it lacks in power on hill climbs and will be happy at 65mph
tha83
Main scooter: SX 2something
Good Luck on that 65 MPH. Seriously. I've got some degree of work into mine and killed two DR kits. Got a Malossi 166 and well happy but there's no way I'm getting 65 out of it. Goes like stink to 55 though. As others have said, P2 lump and call it Macaroni.
goldeneye
cheap option=DR177 kit, standard pipe, 22 tooth clutch cog, up jet standard carb . gives more pull through the gears and a couple of more mph. to get a px125 to do 65-70mph, you need to port cases, modify crank, get yourself a nice exhaust, bigger carb, etc. like the old adage says, CHEAP/FAST/RELIABLE...pick any 2 from them 3 .
philhnottm
Main scooter: px (s)
Buy a Forerunner GPs and you will realise that your 60 mph on the Vespa clock is a real 45MPH less uphill!!
Im still coming to terms with my 65MPH Malossi 166's and 210's .
Damm those Gps Gizmos !!
Neither pull GPS 65 up a hill- However the Diablo Moto Polini 220 does :D :D :D (Get what you pay for I've learnt)
Goldeneye is wise beyond his youth !!
Is anything cheap ??
Relatively.. about 1/3 the price for coops, compared to Lambrettas. :lol:
