Vespa Small Frame CNC Engine Case from BSG......
8646289006_9e5031c1b8_c by drunkmunkey6969, on Flickr
SIP Sales Blurb: Once again vintage Vespa tuning enthusiasts move one step closer to paradise!
Alongside Falc, Quattrini and Co. BSG offer some of the hottest tuning parts available to date. The three letters that make up the company name originate from the surname initials of high-end tuner Fabio Begani, racing legend Stefano Scauri and ET-3 boss Alessandro Graiani. We could stop explaining right here because these guys don't do things by halves. Quite on the contrary BSG and the BSG supported pilots belong to the premier league of Italian scooter racing. Be it in the VPI (Vespa Pista Italia), the CIA (Campionata Italiano Accelerazione) or the new POLINI Cup. With a stunning performance of 48PS, the BSG smallframes was the most powerful scooter on the dyno at the Customshow in Landsberg 2013. It's clear that special components are required to rein such power.
The CNC engine case forms a solid basis for extreme performances. The guys have been working on this project for years and put the engine case to the test in countless races. By now they are ready to sell it to you.
The engine case is CNC milled from solid material. The enormous crankcase provides enough space for the BSG full circle crankshaft with 90.2mm crankwebs. In order to increase the pre-compaction the cylinder base is equipped with no more than a slot in which the conrod moves. Of course this can also be enlarged. The bearing seats are designed for 52x20x15mm crankshaft bearings. Spacers for the crankshaft bearings are included. In order to achieve maximum performance, the crankshaft has to be exactly aligned. The engine case comes with a 19.5mm screw-on spacer that allows of extreme transfer ports. Although you can modify the engine case to use a crankshaft intake, we strongly suggest the use of cylinders with direct intake. Suitable for all watercooled cylinders with 54-64mm Ø bore and 54-56mm stroke. e.g.: FALC, QUATTRINI and PARMAKIT. Karting cylinders (such as TM, ROTAX Ø 60mm) and CAGIVA or GILERA racing cylinders are currently used to achieve maximum performance.
The engine case comes with a detachable shock mount that allows you to use rigid (drag racing) shock absorbers. Also the swing arm is detachable and provides enough room for 3.50-10 tyres. The gearshift arm is ball bearing mounted. You can either use a conventional ignition system, or ignitions made by PVL or SELECTRA. Primary bearing, engine studs and other small parts are included in the scope of delivery. All other components can be taken from a PK engine. The engine case requires the use of a BSG crankshaft. The version with
detachable cover allows of fast adjustments to the gearbox, while the engine is mounted. This way you stay flexible at 150-400m races.
bb1 by drunkmunkey6969, on Flickr
bb2 by drunkmunkey6969, on Flickr
bb3 by drunkmunkey6969, on Flickr
8659243809_af2fea949d_b by drunkmunkey6969, on Flickr
Video:
sibyl
i saw the yellow smallframe in action and had the parts on my desk here... --> sexy!
ESC #700
LI150
Main scooter: Series 2 LI150
Wow makes you want to build an all singing and dancing smallframe. Whats it cost ??
fairspares
that just looks amazing :o and sounds even better.
ArmandTanzarian
LI150 wrote:Wow makes you want to build an all singing and dancing smallframe. Whats it cost ??
I think its probably a case of, "If sir has to ask, sir can't afford."
Wayne Miller
£2.5k :twisted:
Stay tuned..............
cgt75b
Main scooter: lambretta
Wow loving the crisp sound ! Wish I still had my small frame sadly long gone :|
sibyl
http://www.flickr.com/photos/sipscooter ... 935074197/
i recently saw them in action in regensburg :-O
ESC #700
    Users browsing this forum: No registered users and 54 guests
