Ignition system...
Fux
Main scooter: li150 S2
Got a TS1 that needs a new ignition system, whats the best one out there at the mo?
giankx
Rich_T
Main scooter: Li Special
It really depends on which features of an ignition you want and in what order of prefference. Fixed timing or auto advance/retard, programmable advance curve, high power, low cost, power valve controller compatibility etc etc.
You might also want to consider long term spare part availability.
wack 63
Main scooter: '71 GP TS1
Cant fault a Varitronic,mines been on at least 5 years no problem
Fux
Ive also used Varitronic in the past with no probs, so maybee go that way again.
I've never run a varitronic but have heard that the lighting output is poor. Personally I'd probably go with a new BGM with a DC conversion. Wassel, small battery and an Augusto (or similar) if the variable aspect is needed.
Dryballs
My series 1 with varitronic has great lights!
It's a great ignition. In fact I bought a second one when I ruined my first one (my fault)
Fux
Ok. Thats decided then. :)
Have a look at the Casa version of Varitronic, no flywheel issues but that may now have been cured on current Tino Varitronics.
BGM system will be another option though not available yet.
