misfiring rapido 250
tavspeed
hi all,here's the story,rapido 250,tmx35,taffspeed exhaust,sil stator,green wire on cdi disconnected.
bike has been stood since isle of wight last year,drained old petrol through carb float bowl,filled with fresh and she started fourth kick,took for mot last week,seemed all ok.
anyway on the knaresborough to york ysa ride out,it has developed a misfire,it will rev out cleanly in 2nd,but 3rd and 4th wont rev out,misfiring higher up inthe rev range,and worse on a hill,going to strip carb and clean first of all,but i am think stator problem,low tension coil.
but why will it rev out in 2nd and not 3rd and fourth,cheers all.
fairspares
forget carb for now, 1st change plug ,check for loose wire connections into the coil , then plug lead, if long enough try cutting a small piece off each end first before changing complete lead, then try another coil , then stator / timing, more than likely its the plug.
tavspeed
forgot to say,changed plug for a new one,no difference,
fairspares
if it just wouldnt rev out then could have been carb but as it misfired more than likely electrical.
Darrell Taylor
Main scooter: LAMBRETTA
possibly blocked fuel filter following draining full tank of 1 yr old fuel may have left all deposits around filter and causing fuel starvation at higher rpm/prolonged use and under load
Yanker
After much digging missfire/high rpm stutter was due to loose rivets between coil plate and back-plate on a BGM stator....
What flywheel u running?
tavspeed
running standard indian flywheel and stator,going to strip carb and check fuel flow from tap,if ok then on to stator plate,
appreciate the replys,cheers all.
Check timing with a strobe, some times you can visually see the timing marks shoot all over the place if there is a problem.
tavspeed
hi chaps,went to take the carb off, and it fell off,cleaned it out anyway,put back on running spot on,must have been holding on by the skin of its teeth,
so off to cleethorpes fri,can't wait ;)
