Sip digi speedo mph not working ?
simonwwfc
I've checked all settings are all ok . It's only happened since fitted me drop headset only disconnected cable at top . Whilst riding its shows 0 and 1 mph that's its any ideas headset was removed for few days I'm running Italian cable
sideout
Check that the cable square drive is fully inserted in the speedo Simon. Sounds like it's just catching on the edge of the drive socket.
What sometimes happens is the headset top gets pulled up during removal to unscrew the cable ferrule. This stretches the cable outer, when reassembled the inner won't reach.
The best way to avoid this is to disconnect the cable at the hub and push the headset top up using the cable outer, then unscrew it at the top.
hth
Nigel
    Users browsing this forum: Google [Bot] and 17 guests
