PX200 & PX125
Posted: Thu Jun 20, 2013 9:34 pm
by GLscoot
Just bought my first PX200 engine and would like to know which parts of the engine are compatible with the PX125.
Re: PX200 & PX125
Posted: Fri Jun 21, 2013 10:23 am
by Bifter
In what way ?
Re: PX200 & PX125
Posted: Fri Jun 21, 2013 2:23 pm
by gaz_powell
carb top
Oil injector mechanism
flywheel and stator - flywheel cowl
gear selector (provided both are efl) and cover
CDI and bracket
Starter motor (if fitted)
Layshaft (some gear cogs), cruciform, gear tie rod
Parts of the clutch (if Cosa type)
All bearings/seals
Crankcase bolts
Rear hub
backing plate
brake arm
woodruff keys
brake shoes
there are a few other odds and ends but thats about it
None of the main items are a direct swap
Different gearbox, crank, primary drive, barrel piston, cylinder cowl, cylinder studs, carb etc
I`m sure someone can add to the list
Re: PX200 & PX125
Posted: Fri Jun 21, 2013 11:43 pm
by GLscoot
Cheers, thats really what i was looking for. The reason I asked was I have loads of seals, bearings ect. I didnt think the main internal parts were compatible.
