PX200 & PX125
gaz_powell
- registered user
- Contact:
carb top
Oil injector mechanism
flywheel and stator - flywheel cowl
gear selector (provided both are efl) and cover
CDI and bracket
Starter motor (if fitted)
Layshaft (some gear cogs), cruciform, gear tie rod
Parts of the clutch (if Cosa type)
All bearings/seals
Crankcase bolts
Rear hub
backing plate
brake arm
woodruff keys
brake shoes
there are a few other odds and ends but thats about it
None of the main items are a direct swap
Different gearbox, crank, primary drive, barrel piston, cylinder cowl, cylinder studs, carb etc
I`m sure someone can add to the list
CDI and bracket
All bearings/seals
Crankcase bolts
Rear hub
backing plate
brake arm
woodruff keys
brake shoes
