t5 polini kit
ducksta
just took top end of a m8s t5, polini barral, head standard no head gasket? shows signs of piston hitting it+ lump out of piston rings broke and siezed.
question 1 does the head need profiling
question 2 do you run a head gasket in this format
question 3 barral looks ok, cheapest fix (new piston and head sorting)
question 4 would you recomend a full engine strip
ducksta
question 2 answerd
what do polini exactly recomend when using this kit ?
ducksta
base gasket no head gasket profile head just been researching, ive got it to put back together just wonderd if i should strip the whole engine in case any bits of the ring has enterd or have head profiled and new piston
ducksta
all sorted, person who built it put head on wrong way round as well causing more damage then just the head
