End plate problem
biddy
Hi I have a couple of end plate studs rung is there anything other then wielding and taping again any advice would be greatful ;)
joespeed
heli coil
john.t5
Got mine helicoiled, think £20 for 3, you can buy the kit to do it yourself but it's about £35, I've M6 kit, great job.
biddy
The studs are m7 /28mm should the helicoil not be m7
"Time -serts "are far better :D
bsso78
Like Sean said.
If you want a thread repair thats as strong as stuffing the hole with chewing gum and then winding a stud in, use a helicoil.
biddy
I saw beedspeed do a m8 step down to m7 in other words tap out to m8 has one used these before any good
TED CRUD
sean brady scooters wrote:"Time -serts "are far better :D
yup much better !
Smash Ya Pastie
Washington Posse s.c
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 3 guests
