PM crank
sydduckett
Anyone using one of these from PM? Looking for a balanced one for an RB. Would be good to get some feedback before weighing any money out.
http://www.pmtuning.co.uk/pm-tuning-pro ... etta-gp200
ta
Angry Bloke
I'm using one with an Avanti kit but running in so can't really give an opinion . It certainly looks and feels well made though
I took it to CS engineering to check for true before fitting and Chris was impressed ,so that's a good start :D
Angry Bloke
Angry Bloke wrote:I'm using one with an Avanti kit but running in so can't really give an opinion . It certainly looks and feels well made though
I'm sure I paid less than £300 a few months ago
sydduckett
Any good peachy?
Angry Bloke
sydduckett wrote:
Any good peachy?
Hi Sef, Its been Ok so far but I haven't given it any stress TBH , solid build ,as I said CS Eng was impressed :D
Great little cranks those. I use the 62/116 in RB250 builds.
wezly
Worth checking the clearance on the big end shims, the one I had was tight and needed opening up.
sydduckett
Do they come with a selection of shims?
ta
Spanish Fly
Main scooter: P200e
sydduckett wrote:Do they come with a selection of shims?
ta
The shims go either side of the con-rod. They are there to stop the con-rod rubbing on the crank flywheels. If the flywheels have been pressed in too far onto the crank pin during assembly the clearance between the rod, shims and flywheels will be too tight which could cause a seizure when engine warms up. The clearance cannot be increased by a regular home mechanic without specialised tooling.
SF
