JL Curly Springs
What over all length should the springs be that hold the pipe to the stub on a JL Curly ?
Any recommendations for good ones?
psychedelicropcircle
I could have a measure for you next time I'm in the man cave. Pretty sure AF could supply them for you.
Ta, I got a couple with it which are 90mm between the hooks, but they're way too long.
I've seen loads advertised as 65mm, some say 'for the spring bit' and others don't mention what's being measured...I don't want to go getting the wrong ones.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
