PX Kickstarts
Morgan
Main scooter: T5 Vespa Mk1
Just picked up another P2 and sure enough another knackered kickstart. I must have bought half a dozen kickstarts over the past 2 years. Some i've bought i've not even fitted, the quality was so bad, some i fitted lasted a day !! Does anyone know what is a good quality kickstart, either make or supplier ?
OzOAP
Main scooter: Vespa PTS1E
Piaggio
vespaloco
Main scooter: changes by the day
Do you mean the shaft or the quadrant.
Some Spanish PX Kickstarts are steel so a bit better.
In regard to the quadrants had 2 break recently internally due to crap welding.
Morgan
It's the actual alloy kickstart that's been giving me grief. Lambretta ones seem to be steel whereas the Vespa ones are alloy, onto a steel shaft. It's the alloy splines that seem to wear.
GLscoot
Main scooter: Vespa GS150
I have been using the curved kick-start and never had a problem with them. They do seem to be made with better material and in my opinion look better. I did have an original one powder coated and it lasted around 3/4 kicks, dont know if the heat in the process of the powder coating damaged it.
