Page 1 of 2
Avanti + gori + 30mm phbh
Posted: Tue May 21, 2013 12:23 pm
by funk
Hi, I'm after jetting info for the above ,, any one running a gori with they're Avanti? Thanks in advance Mike..
Re: Avanti + gori + 30mm phbh
Posted: Tue May 21, 2013 12:59 pm
by psychedelicropcircle
Does the gori fit the kit.
Posted: Tue May 21, 2013 8:46 pm
by OAP
30m PHBH running without a filter.
Starting point:
Atomiser AV266
Main Jet 122
Pilot Jet 55
X7 needle 2nd notch down
Float valve 300
You must do a 1/4 throttle plug check, pilot jet is the one that may need to be changed, when and if you do, you must repeat 1/4 throttle check.
get some mileage on it (200) & check again. also cut down to 3% oil ratio after 1 tank full
Posted: Thu May 23, 2013 2:02 pm
by Adam_Winstone
Ron,
What slide would you suggest?
Regards,
Adam
Posted: Thu May 23, 2013 3:10 pm
by OAP
a round one :roll:
Posted: Thu May 23, 2013 4:00 pm
by coaster
OAP wrote:a round one :roll:
You Tease 8-)
Posted: Thu May 23, 2013 4:14 pm
by Adam_Winstone
Good advice as I've been trying to shove my VHSH flat slide into my PHBH round body, thanks. :lol:
Posted: Thu May 23, 2013 9:00 pm
by funk
psychedelicropcircle the gori fits straight on,, no fetling
Posted: Fri May 24, 2013 7:46 am
Thank you for the info squire.
Posted: Sat May 25, 2013 8:29 am
by OAP
Hi Adam,
Sorry I got some what side tracked, the PHBH carbs have been delivered with No.40 slides and to be honest I have not seen the need to change them as YET!
