Avanti + gori + 30mm phbh
Hi, I'm after jetting info for the above ,, any one running a gori with they're Avanti? Thanks in advance Mike..
psychedelicropcircle
- registered user
- Main scooter: Series 1 li150 1958
- Contact:
Does the gori fit the kit.
30m PHBH running without a filter.
Starting point:
Atomiser AV266
Main Jet 122
Pilot Jet 55
X7 needle 2nd notch down
Float valve 300
You must do a 1/4 throttle plug check, pilot jet is the one that may need to be changed, when and if you do, you must repeat 1/4 throttle check.
get some mileage on it (200) & check again. also cut down to 3% oil ratio after 1 tank full
Starting point:
Atomiser AV266
Main Jet 122
Pilot Jet 55
Float valve 300
- registered user
- Main scooter: Lambretta GP
- Contact:
Ron,
What slide would you suggest?
Regards,
Adam
Regards,
Adam
- registered user
- Contact:
Good advice as I've been trying to shove my VHSH flat slide into my PHBH round body, thanks.
- registered user
- Contact:
Thank you for the info squire.
Hi Adam,
Sorry I got some what side tracked, the PHBH carbs have been delivered with No.40 slides and to be honest I have not seen the need to change them as YET!
