60mm crank
Posted: Wed May 06, 2009 3:24 pm
by RAP 200
When fitting a 60 stroke crank does ignition timing change;ie,iff timing is set at 18 deg btdc with a 58 stroke and then a 60mm stroke crank is used does stator stay in the same place, and do you still get 18 deg.
Re: 60mm crank
Posted: Wed May 06, 2009 4:47 pm
by shocky
if its a new crank id say check the timing in thery the keyway should be iin the same place in relation to the crank at top dead center are you running a 1mm packer :?:
Re: 60mm crank
Posted: Wed May 06, 2009 9:03 pm
by squeakmillward
no it doesnt change
Re: 60mm crank
Posted: Thu May 07, 2009 2:34 am
by corrado
So, theorectically, is the woodruff key slot always in the exact same place on various cranks?
Re: 60mm crank
Posted: Thu May 07, 2009 8:08 am
by jason frost
When you change any part( crank, piston, flywheel, stator) timing should be checked.
