lth manifold
roadrunnerian
i'm buying a lth manifold for my tmx 35 carb on my ts1 has anyone got photos of it on there scooters need to know if it will interfere with toolbox if tool box has to be removed thanks :D
ssteam177
Main scooter: vba malossi 221, api series2
I had to remove my tool box when I fitted the lth manifold on my monza 225 setup or you could cut out a section of your tool box like they do on the long range tanks
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
ssteam177 wrote:I had to remove my tool box when I fitted the lth manifold on my monza 225 setup or you could cut out a section of your tool box like they do on the long range tanks
Same as with an Imola and TMX27 carb. Removed the toolbox as I have a legshield toolbox anyway.
roadrunnerian
thanks for the replies gents you try to improve one thing than another problem comes along well thats having a lammy ;)
