endplate bearing
scootcoot
Hey... how much play should there be with the xmas tree shaft that comes through the endplate bearing , it seems to move a fair bit ,in and out and side to side ...is this normal ...
Thanks
am a doogal r u a doogal too....!
Muppet
no; best change the bearing; only cheep an worth doin; if y got a vice y can press old'n out and new'n in,
C’est la vie
Jxmiddle
Main scooter: GP250 69 targa twin
As muppet says new bearings makes sense, a few quid and very easy to change. Also if your feeling play in and out that will disappear when you tighten up the nut in the clutch bell which pulls the tree up against the endplate.
scootcoot
Thanks for the advice !! got one on its way !
    Users browsing this forum: Google [Bot], Semrush [Bot] and 7 guests
