endplate bearing
Posted: Fri May 10, 2013 6:50 pm
by scootcoot
Hey... how much play should there be with the xmas tree shaft that comes through the endplate bearing , it seems to move a fair bit ,in and out and side to side ...is this normal ...
Thanks
Re: endplate bearing
Posted: Fri May 10, 2013 7:21 pm
by Muppet
no; best change the bearing; only cheep an worth doin; if y got a vice y can press old'n out and new'n in,
Posted: Fri May 10, 2013 10:20 pm
by Jxmiddle
As muppet says new bearings makes sense, a few quid and very easy to change. Also if your feeling play in and out that will disappear when you tighten up the nut in the clutch bell which pulls the tree up against the endplate.
Posted: Fri May 10, 2013 11:15 pm
by scootcoot
Thanks for the advice !! got one on its way !
