Page 1 of 2
Chrome ring - headset gap
Posted: Sun May 05, 2013 10:23 pm
by victor
When I stripped down my Tv tonight I noticed that there's an uneven gap between the chrome ring and the handlebars:
From right side by
wheredowegonowbutnowhere, on Flickr
From left side by
Untitled by
Since the chrome ring looks ok I'm wondering what causes this? Could it be the clamp...?
Thankful for any feedback - cheers V
Re: Chrome ring - headset gap
Posted: Sun May 05, 2013 11:12 pm
by jason frost
Is the clamp flat ?
Posted: Sun May 05, 2013 11:14 pm
by victor
I don't know to be honest... Can they get un-flat?
Posted: Sun May 05, 2013 11:20 pm
by jason frost
yes looks like its bent at the front
Posted: Sun May 05, 2013 11:36 pm
by victor
So a new clamp will sort it?
The crome ring itself looks 100% straight, and the headset I doubt would get bend, would probably rather crack since it's moulded alu...
Cheers V
Posted: Mon May 06, 2013 9:05 am
by thebassmasta
paint under the headset where clamp meets ? repaired headset? turn the handlebars to full lock, you will see if the headset is not true, if its not true try another set, I cant see it being the clamp, but you never know
Posted: Mon May 06, 2013 9:29 am
by jason frost
If its the clamp it should bend back with a bit of help
Posted: Mon May 06, 2013 9:34 am
by carlos fandango
The gap looks larger at the front . Turn the headset to the left and the right , if the gap is still at the front the problem is the chrome ring. If the gap moves with the headset, then the problem is with the headset .
Posted: Mon May 06, 2013 10:55 am
by victor
Did that, it moves with the headset. The ring seems to be 100% 90° against the stem...
Can the clamp cause this or is the headset to be replaced...?
Posted: Mon May 06, 2013 12:51 pm
by carlos fandango
Take the head set off and unbolt the clamp . It may become obvious what the problem is . The clamp should be parallel to the chrome ring.
