petrol feed for TS1
stokky
ON a TS1, what route do you use to pass petrol pipe across to carb on other side.
Only ask, as when I route over the frame, it tends to collect air bubles, and seems to restrict the flow.
Guessing would be better under frame, so the two hiuhpoints to let air out, would be at tank end and carb end.
Any thoughts ?
What do you do.
Cheers !
bizzly
What I do is make the pipe go to the back of where the bump stop is. It wont catch on the bump stop as I cut the pipe long enough to wedge it between the frame and bottom of the mudguard.
dazz-uk
i picked up a small stick on clip (electricans use them) that you can run a small cable tie in, then stuck to bottom of mudguard and cabled tie it so keeps off the rear wheel and under the frame.
stokky
thanks guys, thought under frame would be the way to go.
Cheers......Martin
