Inlet Manifolds
kejj
Hi all.
I am planning to add a phbl 25mm carburator to my S3 TV175 engine.
I have found 2 different manifolds. The harder one to get hold of is this one by MB:
http://www.scooter-center.com/product/8 ... AUGSTUTZEN
It is out of stock from the regular places I order from.
Can I go with a larger inlet like these ones:
And just use a conversion rubber instead?
http://www.scooter-center.com/product/1 ... AUGSTUTZEN
Or can I even use the mugello manifold on the standard Cylinder?
________________________
http://tv175.wordpress.com/
Andy W
Main scooter: GP 186 Imola
Hi
Have you tried Beedspeed? I fitted one to a mates Li that was fitted with an Ally 175 kit and they supplied the lot.
Andy
kejj
I was trying to avoid shipping over seas. Otherwise Beedspeed has been a main delivery partner for my restoration.
TV175.wordpress.com
gaz_powell
AF have a good range
Timbo
I have one of the MB ones if your interested.
gaz_powell wrote:AF have a good range
That is true and the prices are very cheap but be prepared to do a fair bit of fettling with the dremel, I must have spent a good hour on the one I bought for a 200/225 top end it wasn't even round :shock:
wack 63
Main scooter: '71 GP TS1
Why not port out the original manifold then use a manifold rubber for the 25 mm carb that doesn't have the locating rib in one end. That's how I did my Vega
victor
Main scooter: Tv175 but currently a SS210 :)
I had to do that with the MB one as well. But I suppose there can be differences between the original 175 cylinder's regarding the fin layout?
