Teflon cables
sydduckett
Have been trying to find a set of black teflon coated cables with an extra long throttle cable. Only BGM ones seem to be coming up but everywhere seems sold out.. :( Any Suggestions welcome.
Ta
Sef
Red GP Rider
Main scooter: GP RB 240 Taylor Tuned
Hi Sef
Try these, top quality stuff, slightly pricey but worth it, as the saying goes - you get what you pay for in this life
http://www.venhill.co.uk/
regards
Knowledge
Buy a set of Champion nylon lined cables for gear, clutch and front brake cables.
Next, visit your local cycle shop and buy bicycle brake cable (not gear cable) for the throttle. These are usually nylon lined and comes off a reel, so buy 3m to be sure. You can also buy the ferrules from the cycle shop to tidy-up the loose ends of the outer cable. If you haven't the crimping tool for the ferrule, just glue them on. For the inner cable, just a buy a long one from a scooter shop, and a loose nipple.
If you want a nylon lined choke cable custom built for your scooter (traditional side carb, or shorter ones for the TS1 side carbs), then pm me.
Martin
