brake problem
Posted: Tue Apr 30, 2013 4:38 pm
Front brake on my gts is dragging, any idea why?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
cgt75b wrote:Air in the lines. Give it a bleed with with new fluid should then be ok
does the brake work but then not release ? if so then its the pots in the caliper sticking allthough this tends to happen if been stood a whilebald-scooterist wrote:Front brake on my gts is dragging, any idea why?
