smallframe bearing 204 or 6204?
handofdave
Main scooter: li ts1
hi ,just putting together a kitted 90 and was undecided on choice of flywheel side bearing,got a mazza race small taper crank and ordered a n204 two piece bearing from ve only to discover it is made in india and was hoping for better quality so is it better to go for a high quality two piece roller or a single 6204 ball type bearing big price difference but which way is better for my crank?
thanks
dave
tony
Main scooter: 90ss
Dave I always use the solid bearing. A little more difficult to put together although if you had the large taper crank there is a very neat tool made by Falc to make assembly a diddle. It's not to hard to do. If you want I can post a pic or two to show you.
