Sealing the exhaust
Posted: Wed Apr 17, 2013 12:03 pm
by Bifter
Anyone got any tips on sealing the exhaust at the barrel ? my 210 has a scorpion that is just held on with springs and hence it moves about a bit ,i tried some gum when i refitted it but that didn't work and now the engine is covered in oily gunk .Is there anything out there i can use ?
Re: Sealing the exhaust
Posted: Wed Apr 17, 2013 5:36 pm
by soulboy
holts exhaust sealant easy to use and does the job and real heavy duty springs mate
Posted: Wed Apr 17, 2013 5:41 pm
by rapido230
Sip in Germany do some sleeves to fit between stub and exhaust, still not ideal but closes the gap, made from beer tin by the look of them , so have a tinny then cut it up to size
Posted: Wed Apr 17, 2013 7:01 pm
by Norrie Bodge
Yep As rapido suggests mate
I did same, got some diff thickness sheets off tin-shim
Then wi scissors cut to depth & radius of exhaust stub
Posted: Wed Apr 17, 2013 8:09 pm
by GLscoot
cornflakes & milk
Posted: Thu Apr 18, 2013 10:35 am
by Bifter
Ok guys ,thanks i will give that a go
