Sealing the exhaust
Bifter
Main scooter: vespa p210
Anyone got any tips on sealing the exhaust at the barrel ? my 210 has a scorpion that is just held on with springs and hence it moves about a bit ,i tried some gum when i refitted it but that didn't work and now the engine is covered in oily gunk .Is there anything out there i can use ?
soulboy
holts exhaust sealant easy to use and does the job and real heavy duty springs mate
rapido230
Main scooter: vespa 210 & lambretta gp
Sip in Germany do some sleeves to fit between stub and exhaust, still not ideal but closes the gap, made from beer tin by the look of them , so have a tinny then cut it up to size :)
Norrie Bodge
Yep As rapido suggests mate
I did same, got some diff thickness sheets off tin-shim
Then wi scissors cut to depth & radius of exhaust stub
GLscoot
Main scooter: Vespa GS150
cornflakes & milk
Bifter
Ok guys ,thanks i will give that a go
