progressive springs with anti dive
soupy
About to fit an anti dive break ,I currently have mb progressive fork springs fitted & bgm dampers.It has been suggested that this might lead to an uncomfortable ride and that I should go back to standard springs ,would like to know what others views on this, cheers soupy
cant say for certain but i cant see how progressive springs would make any difference to an anti dive
personally id leave the springs in and see how it feels first rather than pulling them out and not knowing
tea5ive
Main scooter: cometa 140
agree with ric, try your dampers on the lowest setting and work up
fairspares
surely if the anti dive is fitted correctly then this should have no effect on the springs/ damping during riding, the anti dive only works under braking?
soupy
thanks for the reply's will leave as is I couldn't really see the benefit of going back to standard either, cheers soupy
The benefit would be that the right wouldn't be as hard. If I'd got antidive, I'd put regular springs back in in a heartbeat.
soupy
Muttley McLadd wrote:The benefit would be that the right wouldn't be as hard. If I'd got antidive, I'd put regular springs back in in a heartbeat.
hi ,I should have said that im fitting a double disc ,would you still change ,cheers soupy
soupy wrote:About to fit an anti dive break ,I currently have mb progressive fork springs fitted & bgm dampers.It has been suggested that this might lead to an uncomfortable ride and that I should go back to standard springs ,would like to know what others views on this, cheers soupy
Same set up as I've used on my bikes, and works great. The above comment I think was tongue in cheek or an attempt at humour, either way, unhelpful ;-)
rbgaz
i ve got anti dive with mb uprated springs, i also had the bgm dampers but took them of as it felt like the tyre was jumping up n down on the tarmac with no give at all,was fine once took the bgms off
Supereibar
I got told by Guy Topper, that the prog. springs might lead to a very stiff front end. But leave them on, see what happens.
J.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
