Tyre rubbing on clutch housing
Posted: Wed Apr 10, 2013 9:28 pm
by mann
Hi just been for a look at a T5 that's for sale. The plastic cap didn't sit all the way on the hub and the wheel has been rubbing on the clutch housing :?:
there is also a lot of oil on the chassis below the barrell where the brake/ clutch cable enters the frame. Any ideas whats wrong with it. :?
Re: Tyre rubbing on clutch housing
Posted: Thu Apr 11, 2013 8:18 am
by cit205
Tyre rub could have been from a flat tyre, a too wide tyre, or a loose hub . Plastic cap could be wrong cap, or hub split pin interfering .
Oil could be residue from blowing out of the clutch breather, or spit from an exhaust manifold leak , or 2 stroke from an autolube tank leak ,etc . Not necessarily anything major ,depending on how much you know about them and your ability to fix them of course.
Posted: Fri Apr 12, 2013 7:17 pm
by GLscoot
Agree. Get down and give the rear wheel a wiggle, sounds like the hub nut is slightly loose. Ask the seller to remove the plastic cap, split pin, nut cover and tighten the nut. Raise the rear wheel and give it a good spin, or go for a test run and then check the rear wheel for movement again, there should always be a little play. But if it is loose, then its a damaged hub nut, £2 fix. As for oil on the rear and clutch cables, thats normal. The vespa engine gets absolutely boggin in about 10mins, just the nature of the beast. But as before nothing to worry about.
Posted: Sat Apr 13, 2013 7:59 am
by cit205
If it is or has been loose it's the hub splines that get damaged, the softest metal will wear first.
Posted: Mon Apr 15, 2013 12:02 am
by mann
sorted thanks a lot people it was a combination of a soft tyre a loose clutch cover and a cap from a different scoot. I bought it. :D
Posted: Mon Apr 15, 2013 8:12 am
by cit205
8-)
