indian stator plate /flywheel
Posted: Sat Apr 06, 2013 4:38 pm
by skoota2
stop spark,tested white and red (pick up98.7omh)testedwhite and green(lt463.00omh)both ok no spark from red wire,good spark yellow wire ,spark from green .fitted new k2 pickup still no spark. fitted new cdi unit still no spark please help : :?:
Re: indian stator plate /flywheel
Posted: Sun Apr 07, 2013 9:28 am
by rosscla
Taken the ignition switch out of the equation?
Posted: Sun Apr 07, 2013 10:38 am
by coaster
As Rosscla said, if you haven't already done so, disconnect the green from the CDI thay goes up to the ignition switch. This is a common fault especially with pattern replacement ignition switches which short out internally to earth. Also, you don't say it you have replaced the plug/cap/HT lead??.
Posted: Mon Apr 08, 2013 2:14 pm
by skoota2
remove green wire from cdi unit ,no spark ,fitted new ht cable and cap plug still no spark
Posted: Mon Apr 08, 2013 3:21 pm
by Twinny
if not already done try tightning flywheel nut as much as you can then try for spark
john
