Page 1 of 2
Bloody Spring!!!!!
Posted: Sun May 03, 2009 7:02 pm
by sdugg
Please tell me there is an easy way of putting on a centre stand spring.
Tried stand up , scoot lent over , spring puller and then me not being strong enough to pull the bloody thing.
Any usefull tips....
Re: Bloody Spring!!!!!
Posted: Sun May 03, 2009 7:04 pm
by byron
slot some pennies or washers in between a few of the coils, hook it over, then pull them out.
or fit the spring as you're fitting the stand
Posted: Sun May 03, 2009 7:08 pm
by bristolmod
funnily enough I've just done a mates this afternoon.
1) Hook it on the top
2) put a strong screwdriver in the lower hook
3) Put the end of the screwdriver under the attachment on the stand
4) Pull the spring down using the stand attachment as a fulcrum
5) The lower hook of the spring will slip over the stand attachment
Be warned- the spring is strong and it may slip off the screwdriver. Mind your eyes/ body/ fingers- it hurts
Posted: Sun May 03, 2009 7:25 pm
by joespeed
there is a proper tool for this ,it is like a screwdriver but the blade is curved,i personally use a screw driver guided by a pair of pliers ,when the spring 'twangs' so does your temper!
regards
joe
Posted: Sun May 03, 2009 7:34 pm
by coaster
bristolmod wrote:funnily enough I've just done a mates this afternoon.
This method works for me too but I'll be trying Byron's method next time I do it. cheers Jarv
Posted: Sun May 03, 2009 7:48 pm
by hydra
As said already, by far the best way is to fit the spring to the stand and frame and then fit stand bolts.
Posted: Sun May 03, 2009 9:25 pm
by rog60
Posted: Sun May 03, 2009 9:49 pm
by Andy Pickering
Ditto...but I did use byrons method last year from his advise cheers byron..
Posted: Mon May 04, 2009 1:10 am
by RBG
I attach it before fitting the stand.
Posted: Mon May 04, 2009 11:06 am
by simon
I used a big screwdriver doing the series 2, it scraped the paint on the stand tho
was to lazy to take the stand off
