Rapido 230 Jetting Advice
servetakid
Does any one have any advice for a race rapido 230 wIth 30mm carb. I am running any NK Rally Road pipe, but just after some ideas.
servetakid
It's a 30mm PHBh
DaveTomo
Main scooter: SX 200
according to the AFR jetting chart for a race rapido 225 with an expansion,should get you somewhere near
Main 128
needle jet AV266
needle X7 second clip
slide 30-40
pilot 55
choke 70
mixture 2.5 to 3.5 turns out
servetakid
Cheers for that, I will use that as a base and up-jet from there.
I would be interested if any one has any jetting advice from any piston ported 230 with the 30mm PHBH?
