series 2 key ignition
wurzel
Main scooter: TV 175 / JET 200
Am I right in thinking that if I change a series 2 to key ignition I would have to use a TV 175 series 2 type and where would I get one or are there any other types that will fit. Would I also need the TV type light switch.
Cheers Mark
I would have thought that you could fit a Casa ignition switch. You can't fit the TV light switch and surround to an Li headset, the holes are in different positions. Li lower headset is different to a TV one.
DigDug
As corrado said you only need to use the switch as a kill switch with the green wire and not touch anything else.
Did you have to do that?
jason frost
Apart from the pink :)
Sent from my BlackBerry 9300 using Tapatalk
wurzel
Cheers folks
DigDug
jason frost wrote:Apart from the pink :)
It's been a while since I touched the pink.... ;)
squeakmillward
tipping the velvet :D only memories :D
jason frost
LOL
wurzel
last time I got me hands on the pink I accidentally touched it with the purple and it blew a fuse :shock:
thebassmasta
Main scooter: GP TS1 240
just wire it up the same a gp/li/sx use the ignition switch as your main switching, just isolate the wires on the handlebar switch for the lights, wire up the horn and dip switch, simples
    Users browsing this forum: Google [Bot] and 15 guests
